What should the proper fpm velocity be for a furnace in a
1000 sq foot ranch house? Quite open inside without walls every 5 feet. Only the single bedroom and bathroom are partitioned off. Blower is rated for 1000cfm. Just trying to decide which ducting size for the supply. Then I'll just increase it a bit for the return. Any help is greatly appreciated folks!
thinking 700
does that sound adequate?
At 700fpm
Your at less then .05 SP you should be able to go up to 900 fpm with no real noise.
