The Wall
Forum / THE MAIN WALL / ? convert push nipple to threaded on WM snug CIBB?
  • Post a Reply to this Thread
    ? convert push nipple to threaded on WM snug CIBB? (8 Posts)
  • deaner deaner @ 4:43 PM
    Contact this user
    Is there a way to convert the push nipple on middle sections of WM snug fit CIBB rads so that they can be used as end pieces.  I realize that I would have to use blocking for the feet.  Thanks  G
  • bob young bob young @ 4:55 PM
    Contact this user
    drill & tap
    sure drill & tap , then connect . what could be easier.
  • icesailor icesailor @ 7:26 PM
    Contact this user
    Doing:
    Just because something might be possible to do, doesn't mean it is a good idea to try it.
    There is more than you have noticed about the end sections. They hold the rods that hold the sections together. They have a lot of tapping's for the feeds and the air vents. They also make a way to end the fins.
    I shouldn't say anything. Some people will try anything to find out it doesn't work.
  • deaner deaner @ 9:23 AM
    Contact this user
    baseboard cast iron
    I was asking specifically about cast iron baseboard radiators.  With this info do you still think tap/dye is not the way to go?  The sections that I have already have an upper and lower hole to fit a push nipple.  Thanks. G
  • icesailor icesailor @ 8:09 PM
    Contact this user
    The same applies:
    The same amswer is still in effect.
    You can do anything you want. Just not everything you want.
  • Charlie from wmass Charlie from wmass @ 8:32 PM
    Contact this user
    In a pinch
    They can be tapped. Why do you want to do this is my question. I have had to due to freeze ups and needing to get the heat on as the end section is toast. I also have sections of New Weil and AmStan I will never get rid of just incase I need them for repairs.
  • deaner deaner @ 10:02 PM
    Contact this user
    reply to charlie from wmass
    Charlie,
    I have numerous middle sections but no end sections.  I thought if there was a way to use the middles as ends it would save me buying new ends.  Just exploring my options. Thanks.  G
    Contact this user
    Charlie,
