Forum /
THE MAIN WALL /
yellow stuff
Post a Reply to this Thread
yellow stuff (8 Posts)
yellow stuff
coming out of flue pipe joints. Any ideas on what this could be? A new furnace and water was recently installed in this house. The house was renovated, and hasn't been lived in about 4 months. Heat has been set on 60 degrees because it has been vacant. Thanks. -
sounds like....
the flue gasses are condensing in the flue. Give us more info on the system....radiators? Baseboard? Hot water?Steam?hot air? gas? oil? Boiler model? -
that's exactly
what I was thinking. 100,000 btu hot air furnace, 40,000 btu water heater. Like I said they are keeping the temp set low at the house because no one is living there. Also, I noticed that the bvent flue goes up the center of the house and terminates through the roof with no cap. There is some fake looking chimney around it made of metal. So i'm thinking cold air is pouring down that pipe and just condensing the gases. Make sense? Why is the condensate yellow? What's in the flue gases that makes water turn yellow? thanks again -
sulfur
is yellow. and u haven't said the fuel your using, if it was my guess it's NG.This post was edited by an admin on February 25, 2013 9:10 AM. -
sulfur
is yellow -
yes
it is natural gas. Is there a little sulfar in the fuel, or in the combustion air? -
u r
getting condensate in your flue or allot of rain. do u have a drip leg on the flue? got pics? and as for what kcopp ask for? -
Yellow Stuff?
If my memory serves me correctly I believe the minium return air temperature
furnace manufacturers like to see is 60* coming back to their units (Carrier
& Lennox for sure) for any sustained time. This could cause condensation
problems.
