The Wall
Forum / A-C, Heat Pumps & Refrigeration / Duct vs Ductless Air Conditioners
  • Post a Reply to this Thread
    Duct vs Ductless Air Conditioners (4 Posts)
  • jeff768 jeff768 @ 12:37 PM
    Contact this user
    Hi this is my first post,
    I have 1250 sq. ft cabin that I keep at 72 degrees. To do this I have a 12000 BTU and a 6000 BTU and another 6000 BTU. I’m tempted to reinvest in a new system but I was wondering if it makes more sense to switch from a ductless system to a duct system.
    Here are my options:
    1) Replace my 3 units with 3 more units with the same BTU’s
    2) Replace my 3 units with 1 big unit (24000 BTU’s say,)
    3) Replace my ductless system with a duct system.
    No matter the system I reinvest in, it’ll probably cost me a lot which is fine, I`m not here to compare prices. The question I have for you pros is which is the most sustainable future equipment investment strategy? Basically which option will give me the most bang for my buckÉ
    Note: The matter is a bit more complex because some mini-split air conditioners qualify for a federal tax credit due to The American Tax Payer Relief Act of 2012.
    Sources:
    http://senville.com/air-conditioner-tax-credits/ or here http://en.wikipedia.org/wiki/America...ef_Act_of_2012
  • Jack Jack @ 5:56 PM
    Contact this user
    Keep in mind
    that your current ductless system is "net to the space" and there are no duct losses. Given the increase in efficiency of the mini-splits and the heating performance increases at low temps, I'd upgrade the mini-splits and give up on the thought of ductwork. What I did is pull my ducted system and install mini-splits. I put a single 25 Seer unit in the primary living area and a dual unit in the upstairs bedrooms. Adding an addition this spring for new kitchen and new bathrooms I will put another super efficiency unit in the common area of the kitchen and be done with it. Personally, I will never put ductwork into my house again.
  • Ironman Ironman @ 8:33 PM
    Contact this user
    Agreed
    I can't imagine any benefit, only liabilities, by swapping ductless for ducted.
    Bob Boan
  • TonyS TonyS @ 8:02 PM
    Contact this user
    Same as Jack
    Pulled my ducted system and installed 3 ductless. Far better control over humidity. Ductless units are to AC as modulating boilers are to heating...the unit is the right size every day.
