The Wall
Forum / Strictly Steam / Ols steam system, troubles come my way?
  • Post a Reply to this Thread
    Ols steam system, troubles come my way? (7 Posts)
  • GW GW @ 12:59 PM
    Contact this user
    Old steam system, troubles come my way?
    I'm looking at this job, it's a combination of one and two pipes, older snow man type of sections (vertical), my camera ran out of battery juice before I could snap a pic of the whole boiler. This caught my eye, this is at the boiler and the 1" heads over to the chimney and apparently vents into the flue.
    Any ideas what kind of system i am looking at?
    New boiler going to be trouble?
    It's 566 sq ft, probably stick in  a peerless 63-05
    I already quoted it, packed in a few dollars for surprises.
    Thanks, Gary
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    This post was edited by an admin on March 18, 2013 1:00 PM.
  • GW GW @ 1:01 PM
    Contact this user
    Relief?
    If that's a relief valve, that would be a 1st!
    Gary Wilson
    Northampton, MA
  • Jamie Hall Jamie Hall @ 4:08 PM
    Contact this user
    More pictures, more description
    badly needed.  That 1" could be an old old main vent; the Dead Men sometimes did that for vapour systems.
    As far as the new boiler is concerned, if it's properly sized to the radiation, properly piped according to its manuals, and if it is set with the water level within an inch or two of the original, that shouldn't cause you a problem.  If any of the above are not done, you will likely have problems.  Do it right the first time; it's cheaper.
    Control the boiler with a vapourstat.  If it is an old vapour system, start at eight ounces cutout and play from there.
    Look everywhere.  How (and where?) is the venting?  How are the traps?  How are the pipe pitches?  etc.
    If you're starting with a snowman, the odds are that some of the rest of the system may not have seen much work in the last few decades, either...
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • GW GW @ 6:33 PM
    Contact this user
    Ok thanks
    Jamie ill get more pics
    Gary Wilson
    Northampton, MA
  • Dave in QCA Dave in QCA @ 9:10 AM
    Contact this user
    O-E Sytem Exhauster
    It looks like you have an O-E system.  The device that you show is the exhauster.  It vents the entire system and discharges vented air into the flue.  Here is a link that tells all about the system.   http://www.heatinghelp.com/files/articles/1380/78.pdf
    It should not be a problem to install this system but you might want to read the system description very closely and also survey the system to see what is still there and what has been removed.  The guy installing the boiler is expected to make the heating system work.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Charlie from wmass Charlie from wmass @ 10:36 AM
    Contact this user
    Yep it's an OE
    It is a vent you will need to find a different way to vent the system. I would have guessed pressure relief for sure. Just do a proper piping job and vent the mains well and you should be fine.
    cell # 413-841-6726
    This post was edited by an admin on March 19, 2013 10:41 AM.
  • Charlie from wmass Charlie from wmass @ 10:42 AM
    Contact this user
    Gary you can always
    drop them my number if you would prefer to not mess with it. Just saying.
    cell # 413-841-6726
