The Wall
Forum / Strictly Steam / Boiler releases water but continues to stay on
  • Post a Reply to this Thread
    Boiler releases water but continues to stay on (4 Posts)
  • queens queens @ 9:28 AM
    Contact this user
    My boiler has run dry a few times,the first /second time the lwco switch shut everything down.Everything went back to normal.It has happened on more occasions and  now as I refill it it leaks water for a little while (pressure release ?) and then it stops.Then I'm able to refill it, it runs fine throughout  the day, then the next morning I notice water has leaked again and the boiler is running dry again.Is it a problem with the pressure release valve ? How can I check ? Main board ?
    Thank You
  • nicholas bonham-carter nicholas bonham-carter @ 9:40 AM
    Contact this user
    Find a contractor button
    You will need professional help for this problem, as it seems your boiler has begun to leak.
    He should overfill the boiler, and then look for the leak.--NBC
  • KnaveP KnaveP @ 1:04 AM
    Contact this user
    Boiler or return lines?
    Is it that the boiler is leaking or is it losing water due to a leak elsewhere?
  • JStar JStar @ 9:09 AM
    Contact this user
    Boiler
    SHUT THE BOILER OFF. DO NOT USE IT,
    You have a major safety hazard right now. Don't use the boiler until you can have it fixed or replaced.
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
