The Wall
Forum / THE MAIN WALL / Boiler room door
  • Post a Reply to this Thread
    Boiler room door (3 Posts)
  • KeithB KeithB @ 9:43 PM
    Contact this user
    Boiler room door
    My boiler is in a very small closet in a finished basement. I added a direct air intake to the boiler from outside and want to replace the closet door. I have the following questions:
    - If I install a wood door, does it need metal flashing on the inside by code?
    - what door vent products are recommended to reduce noise?
    Thanks in advance for your help.
    Keith
  • unclejohn unclejohn @ 12:16 AM
    Contact this user
    Need to
    Ask someone in youe area. The old local codes apply rule is in play.
  • KeithC KeithC @ 9:25 AM
    Contact this user
    door
    Without knowing where you live, we couldn't tell you what the code is. Give a call to your local department of buildings and ask to speak with an inspector. Usually they're very helpful.
    Keith
