The Wall
Forum / THE MAIN WALL / Pressure rising to 60psi
  • Post a Reply to this Thread
    Pressure rising to 60psi (13 Posts)
  • Steve Garson Steve Garson @ 3:46 PM
    Contact this user
    I had to replace a leaking expansion tank last week on a radiant heating system. I installed a new one with a 20psi charge and charged the system to 20psi. The water-feed valve was then shut off.
    A few days later, I saw the pressure gauge reading of 60psi. Puzzled, I drained around 2+ quarts of water and the pressure went back down to 20psi.
    Today, the pressure was high again, so I drained some more. The water temp varies from 100* to 140*.
    This all seems wrong. What is happening here?
    Thanks,
    Steve Garson
    Boston, MA
    Steve from Newton, MA
  • icesailor icesailor @ 3:49 PM
    Contact this user
    Leaks:
    There's a leak from the high pressure (Potable, Street) side to the lower pressure, closed heating side somewhere. A indirect coil most likely.
  • Steve Garson Steve Garson @ 4:11 PM
    Contact this user
    Leak
    That makes a lot of sense. This is my second Combicore. It is perhaps five years old. I wish my contractor installed a small boiler, instead. Any suggestions on the smallest boiler available>
    Steve
    Contact this user
    Leak
    Steve
  • RobG RobG @ 4:02 PM
    Contact this user
    Relief valve
    On top of what Ice said, that relief valve shoud have never let the boiler get above 30 psi (unless it is a rare system that is rated higher). Check the relief valve as well.
    Rob
  • Steve Garson Steve Garson @ 7:09 AM
    Contact this user
    No relief
    Just noticed...no relief valve on heating loop. Only on potable hot water side. Unbelievable!
    Contact this user
    No relief
    Contact this user
    No relief
    Contact this user
    No relief
    Contact this user
    No relief
    Contact this user
    No relief
    Contact this user
    No relief
  • Steve Garson Steve Garson @ 7:10 AM
    Contact this user
    No relief
