The Wall
Forum / THE MAIN WALL / Heat Loss up chimney for water heater
  • Post a Reply to this Thread
    Heat Loss up chimney for water heater (3 Posts)
  • Jfonto Jfonto @ 12:26 PM
    Contact this user
    Anyone know what the heat loss for a chimney,with only a hot water heater on it , would be.
    I'm think of going to a direct vent unit and block off chimney.
  • Jfonto Jfonto @ 1:16 PM
    Contact this user
    To be specific,
    what's the heat loss from the draft drawing out heated air and sucking in cold?
  • chapchap70 chapchap70 @ 5:06 PM
    Contact this user
    It Depends
    Obviously, the colder the outside temperature and/or the higher the water temperature in the heater, the greater the heat loss.  A direct fired water heater can lose 8 degrees per hour when really cold.  A direct vented water heater will have heat loss as well (maybe not quite as much?) unless there is insulated venting with a damper (which I'm not sure is available or practical).
    My thinking without really investigating it is it would not pay to do this.
