The Wall
Forum / THE MAIN WALL / Pump for Washing machine
  • Post a Reply to this Thread
    Pump for Washing machine (11 Posts)
  • hrlevy hrlevy @ 8:53 PM
    Contact this user
    I am looking for a permanent fix. Our washing machine is 7ft below the sewer pipe exiting the basement. What would be the simplest - best fix for this?? The drain currently empties into a wash tub that goes to an old dry well. The dry well is no longer a valid option.
  • hot rod hot rod @ 9:38 PM
    Contact this user
    the pump
    in the washer may lift 7"? Buy some inexpensive sump pump hose, couple onto the washer drain hose, and try it.
  • icesailor icesailor @ 8:44 AM
    Contact this user
    High Pumping:
    The only problem you may find when pumping that high is that the water pumps out slower out of the machine. On some machines, the times cycle may not get all the water out on some cycles. But I haven't found any customers to notice or complain.
    If it was draining into a laundry tray, you can add a pump to that and still use the sink/tray. The pumps aren't all that expensive. They are designed for this application.
  • hrlevy hrlevy @ 11:17 AM
    Contact this user
    my idea was
    I was thinking about installing a sewerage tank with a grinder pump
  • SWEI SWEI @ 12:03 PM
    Contact this user
    grinder pump
    would be overkill for laundry, but there is no shortage of options
    http://www.libertypumps.com/Products/Category/?c=15
  • icesailor icesailor @ 5:19 AM
    Contact this user
    Suit your self:
    Suit your self.
    You can blow a hole in the floor and install a 18" X 30: sump basin and pump. There are a large number of ways to do this. Cost is the only limiting factor.
    I would start with lengthening the drain hose and let the pump go up. I have never seen a washer that wouldn't do it in a "normal" cellar. The cheapest ones work the best. If it is a front loader, raise it up so you don't need to bend over to get the clothes out of it.
    Or get out the demo hammer.
    I'm sort of a low technology kind of guy. If the washer pump will do the job, that's what I do. I'm going to turn on the water to a house that has one. It has been in for many years. It was there when I took it on and pumps fine. When I drain it for the winter, I use 6 cups of anti-freeze instead of 4.
    Contact this user
    This post was edited by an admin on March 30, 2013 11:18 AM.
  • Zman Zman @ 2:05 PM
    Contact this user
    Front loader
    I have had good luck using a front loading model and putting it on a platform. Most models make one with a drawer underneath.
    If you want to keep the wash tub, any inexpensive lift will work. Zoeller makes a nice one.
    Carl
  • unclejohn unclejohn @ 2:34 PM
    Contact this user
    The best
    Fix is to move the washer up where the drain is. That will also make the little women happy since she won't have to keep draging the clothes up and down the stairs. Bring the dryer up as well.
  • Many manufacturers
    sell this type of system:
    http://www.plumbingsupply.com/gray-water-laundry-pump.html
    The laundry tray acts as a reservoir since the pump is not powerful enough to keep up with the washing machine.
    I have a Myers pump attached to my laundry tray in the basement and it works extremely well.
    Often wrong, never in doubt.
  • bob eck bob eck @ 8:03 PM
    Contact this user
    Pump
    Look at the liberty pumps 404 www.llibertypumps.com
