The Wall
Forum / THE MAIN WALL / Electric boiler
  • Post a Reply to this Thread
    Electric boiler (4 Posts)
  • Zman Zman @ 11:44 PM
    Contact this user
    Electric boiler
    Is there any downside to controlling a large electric boiler with outdoor reset?
    I am working on an "always on" commercial system that has a tendency to overshoot.
    Can you damage an electric boiler by turning down?
    Thanks,
    Carl
  • SWEI SWEI @ 1:44 AM
    Contact this user
    how are you turning down?
    Most large electric boilers I've seen have multiple elements and some kind of switching.  The newer ones have TRIAC controls, which can be retrofitted to almost anything.
  • Zman Zman @ 8:23 AM
    Contact this user
    Control
    Swei,
    I have seen a graph of the boiler's energy use. It appears to be a multistage setup with multiple elements. I will open it up and figure out what controls the beast on my next visit.
    Carl
  • SWEI SWEI @ 11:56 AM
    Contact this user
    Assuming it has a control input
    an off-the-shelf ORC (possibly with some kind of adapter if it's an older interface) should get you there pretty easily.
    If not, I'd replace either the low voltage side or everything in front of the elements depending on what was in there.
    http://www.viconics.com/electric_heat.php
    http://indeeco.thomasnet.com/category/all-categories-indeeco-controls-controls
