The Wall
Forum / Oil Heating / Failing Aquastat?
  • Post a Reply to this Thread
    Failing Aquastat? (2 Posts)
  • T_RO T_RO @ 9:02 AM
    Contact this user
    Failing Aquastat?
    I have a 20 year old weil-mclean 68V with tankless coil, 4 zones, circulators, Tjernlund PV, Honeywell L8124A,C aquastat.
    A couple times this past week my boiler temp was 120 degrees or less before it fired. My settings are 160, 180, 10 diff. Is my lo switch failing? Is there a way to test it? The only thing I've done is run them around a little. This aquastat is ~5 years old.
    Edit: add'l info this morning at 400 am house pretty cold when wife got up. no hot water in shower, when I got downstairs boiler was running and at about 130 by then. temps were in low 20's wouldn't have a call for heat started the burner?
    Also, I have been thinking about installing an electric hot water heater, if I do so I assume I could go with a different type aquastat that only has a Hi setpoint?
    Thanks
    This post was edited by an admin on April 2, 2013 10:31 AM.
  • billtwocase billtwocase @ 8:13 PM
    Contact this user
    power vent
    How is it wired? Sounds like they are using B-1, and the fan prover is not always, or delaying the power supply to the primary control.
