The Wall
Forum / Strictly Steam / Crab steamer
  • Post a Reply to this Thread
    Crab steamer (7 Posts)
  • LWH LWH @ 9:19 PM
    Contact this user
    Crab steamer
    Any tips on installing a steam boiler to steam crabs...hot water for make up from water heater or coil, piping diagrams etc
  • nicholas bonham-carter nicholas bonham-carter @ 10:02 PM
    Contact this user
    Constant loss steamer
    There are a few postings here on that subject, so do a search.
    The problem to be overcome is the constant addition of fresh waste to the boiler which can introduce too much oxygen into the boiler hastening it's demise.--NBC
  • Steamhead Steamhead @ 10:04 PM
    Contact this user
    Here's one we did
    in the back of a truck, no less............
    http://www.heatinghelp.com/forum-thread/138701/In-the-Land-of-Pleasant-Living
  • Dan Holohan Dan Holohan @ 10:53 AM
    Contact this user
    Feed water
    Feed it through a small water heater, set at the highest temperature, and use a microbubble reabsorber in the feed line. That will take care of the air and the heater will give the sediment a place to settle, other than inside the boiler. Adds years to the boiler's life.
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
  • vaporvac vaporvac @ 2:22 PM
    Contact this user
    WaterHeater, microbubble reabsorber?
    If this works to prevent the introduction of co2 into the system, why isn't it used with residential steam for make-up water?
  • JStar JStar @ 4:15 PM
    Contact this user
    Steam
    Why, indeed.
    The reason is...no reason.
    The REAL reason is that a residential boiler should not be using a lot of fresh water. And if water is added for maintenance, it should be boiled immediately. Whatever sediment accumulates over the years can be cleaned out.
    In this crab steamer, there is so much fresh water being used daily, that you there is no way to maintain it often enough to prevent a problem.
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • Hap_Hazzard Hap_Hazzard @ 8:49 AM
    Contact this user
    You can use hot water for make-up water
    But don't run it through an automatic water feeder.
    (Actually, consult your local code. It might not allow this.)
    1983(?) Peerless G-561-W-S
    3" drop header, CG400-1090, VXT-24
    This post was edited by an admin on April 7, 2013 8:51 AM.
