The Wall
Forum / Oil Heating / Return line or no return line?
  • Post a Reply to this Thread
    Return line or no return line? (5 Posts)
  • hh409 hh409 @ 6:13 PM
    Contact this user
    General consenses seems to be that return lines are not beneficial other than not having to bleed for trapped air. Why are some systems comfigured with a return and others not?
    I just installed a 275 basement tank, the tank feeds fron the bottom,is about 6 ft from the burner inlet and the tank bottom feed is at an elevation about 4 inches lower than the burner feed. It has been run with the return line but if advisable i will convert to a one line system. The old system was a 550 inground tank about 20 feet away. Does the return line benefit more when the tank is below ground or farther away?
    Thanks
  • Ron Jr. Ron Jr. @ 8:42 PM
    Contact this user
    No benefit at all
    to having your burner run on 2 pipes . Other than you don't have to bleed the pump to prime it :)  I'll bet they connected the new tank 2 pipe because they didn't want to mess with the bypass plug in the oil burner ........
    On 2 pipe you're pumping somewhere around 20 gallons an hour through the oil lines and filter and pump , and most of it goes right back to the tank . No need to put all that oil through the system and plug up the fliter and strainer alot faster ...... and also the potential of the return line leaking ..........
    With the tank so close you will have no problem running it with one pipe . Even if the tank runs lower than the burner an inch or a few .
  • STEVEusaPA STEVEusaPA @ 9:43 PM
    Contact this user
    Very important..,,
    If you convert back to one pipe, don't forget to remove bypass plug.
    steve
  • Ron Jr. Ron Jr. @ 7:41 PM
    Contact this user
    Yes !
    Forgot to mention that ! Remove the bypass plug or the pump will have a very short life .........  Unless it's a Riello !
  • billtwocase billtwocase @ 6:57 PM
    Contact this user
    ditto
    What Ron and Steve said. One pipe should do the trick. Two pipe used to be the norm years back.  Advantage would be a spare line should the feed line become an issue with an underground tank.
