The Wall
Forum / Oil Heating / Old 550 in ground tank, how many inches is absolute minimum?
  • Post a Reply to this Thread
    Old 550 in ground tank, how many inches is absolute minimum? (4 Posts)
  • hh409 hh409 @ 6:20 PM
    Contact this user
    I was looking to run my old 550 in ground tank to absolute minimum before hooking up my new 275 basement tank. The old 550 is from the 1950's . Typically how far above the tank is the pickup and how many inches of oil would you estimate absolute bottom?
    Thanks
  • STEVEusaPA STEVEusaPA @ 9:40 PM
    Contact this user
    The only way to know....
    Without historical data from a run out, is to let run out. Everyone installed them differently, and if there was a water problem in the past, someone could've pulled up the line a little. Typically we install the new tank, fill it, run line over to burner, and run the old tank until its dry. Then do a proper change over.
    Along with your other post, if you convert to one pipe, don't forget to remove bypass plug
    steve
    This post was edited by an admin on April 3, 2013 9:45 PM.
  • hh409 hh409 @ 4:46 PM
    Contact this user
    thanks for the info
    got it
    thanks for the info
  • billtwocase billtwocase @ 6:53 PM
    Contact this user
    I always
    pulled the suction line up about 4" off the bottom. Is the tank stickable?
