The Wall
  • Post a Reply to this Thread
    Tekmar 406 (2 Posts)
  • J Matthers J Matthers @ 8:59 AM
    Contact this user
    Tekmar 406
    I am replacing a single stage GSHP with a two stage unit. The current controls include two Tekmar 420 boiler resets to run the HP and a Knight 80. the zones (5 heat, 2 cool on HP and 4 heat on Knight) are controled with three 336 zone pump managers. All zones have TNet4 therms, 541's and 544's. I would like to incorporate the new 406 house control to run the HP and need comfermation that it will "play well" with the 336 zone managers allowing to leave the therms and pumps wired as is. This would also cut cost significantly so I can splurge on a few of the new 557 therms to replace the 544's. Can one of you familier with Tekmar comment? rough drawing attached. Thanks
  • zacmobile zacmobile @ 11:34 AM
    Contact this user
    I would
    I would say definitely maybe. The 406 does have a tN4 input but I don't know how extensive it's capabilities are, I think it's just intended as a setpoint or scene switch input. If you haven't already I would get on the horn with tekmar tech support, they are very helpful and will set you straight right away.
