The Wall
Forum / Radiant Heating / side arm heat-x advantages and disadvantages
  • Post a Reply to this Thread
    side arm heat-x advantages and disadvantages (2 Posts)
  • andrew123 andrew123 @ 8:37 PM
    Contact this user
    are there any disadvantages to installing a side arm heat exchanger on an existing electric water heater,to be connected from the primary loop of a cgi ng boiler currently feeding 2 air handlers.
  • KCA KCA @ 2:48 PM
    Contact this user
    Do you mean
    Have a plate exchanger pre-heat the water before it goes into the water heater?
       Then ....   No down side that I can see...
    You likely wouldn't even need the elec. heater to be on if it were piped right...
