The Wall
Forum / THE MAIN WALL / Add Existing Hot Water Baseboard Heat To Unfinished Basement?
  • Post a Reply to this Thread
    Add Existing Hot Water Baseboard Heat To Unfinished Basement? (3 Posts)
  • snowking82 snowking82 @ 12:51 PM
    Contact this user
    Hi,
    I'm purchasing a house that has hot water baseboard heating.  The basement is unfinished, but I was just curious to see what it would cost to add baseboard heating to the basement?
    Thank you!
  • Paul48 Paul48 @ 1:17 PM
    Contact this user
    Price
    Can't discuss pricing. It's a rule of the site. Before you jump in, you need to find out if the boiler will support adding emitters. You need to do a heat loss of the structure and compare that to the boiler. I'm pretty sure the current owner won't tell you that a certain bathroom, or bedroom is always freezing. The heat loss will let you see if certain areas don't have enough emitters, and take care of that, now.
    This post was edited by an admin on April 16, 2013 1:29 PM.
  • bob eck bob eck @ 7:50 PM
    Contact this user
    Adding copper baseboard zone
    Get a heat loss done on the house and the basement. You can zone the basement as one zone and the house as another zone. You can give the house zone priority over the basement zone. How is the hot water heated? You could use a indirect water heater and give that zone priority and use programmable thermostats in the other zones so you can control what zones will be running at what time and keep each zone at the temperature that is comfortable for you and your family.
