The Wall
Forum / THE MAIN WALL / Taco 5000 O- Rings
  • Post a Reply to this Thread
    Taco 5000 O- Rings (2 Posts)
  • oldpipefitter oldpipefitter @ 6:11 PM
    Contact this user
    Taco 5000 O- Rings
    Have 3 Taco 5000's (1/2") 3- way valves leaking out from under the adjustment knob. Found the replacement instructions on Taco's site but no where can i find the part number for the parts kit. Can anybody help with this. I just want to make sure i get the right kits when I order them from my local supply house. Thanks!
  • heatpro02920 heatpro02920 @ 9:21 AM
    Contact this user
    Tough call
    5001-001rp is the number on the element kits I stock on my trucks, but the problem is that costs me almost as much as a new valve , so I normally change out the valve, its faster, easier, and guaranteed to work, vs pulling apart a corroded old valve, and reusing the body...
    Good luck, another option is to call Taco, and see if they will send you a seal kit, they are really easy to work with...
