The Wall
Forum / Radiant Heating / Ultra Oil multi temp piping
  • Post a Reply to this Thread
    Ultra Oil multi temp piping (3 Posts)
  • bagcag2 bagcag2 @ 9:03 PM
    Contact this user
    I have been tasked with correcting a job that someone else has done.  What I have I a Weil-Mclain Ultra Oil boiler.  It is piped with a supply and return manifold.  It has several hi temp zones and several radiant zones.  What I do not know is can an UltraOil boiler be piped with primary and secondary loops and work efficiently or is there a better suggestion.  The reason for this job is the radiant part is piped incorrectly, looks messy and the customer wants it moved.
  • SilverCheetah SilverCheetah @ 9:45 PM
    Contact this user
    Pictures, Charts, & Graphs
    It is suggested that you provide very clear pictures and/or diagrams (drawings). The radiant portion should have a mixing valve to allow the return side mix with the hot supply side. Temperature of the boiler, etc.  Information on how many pumps, location of pumps, etc. would be helpful. How do you know the radiant heating system is piped incorrectly? The radiant portion should have its own circulator pump (sized properly) for the correct flow, etc. The more clear precise information, the better advised the forum members can be. Please advise!
  • Chris Chris @ 7:46 PM
    Contact this user
    Suggest You
    Start with some nice reading material. Then a heat loss. Please find the attachments for enlightenment. I'm pretty sure Page 17 of the Installation Manual answers your question.
    http://www.weil-mclain.com/en/assets/pdf/uo_manual.pdf
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
    This post was edited by an admin on April 18, 2013 7:50 PM.
