The Wall
Forum / THE MAIN WALL / Does anyone make a mini-split with 8 indoor units and 1 each 4-ton heat pump unit, 3-phase?
  • Post a Reply to this Thread
    Does anyone make a mini-split with 8 indoor units and 1 each 4-ton heat pump unit, 3-phase? (5 Posts)
  • Howard Howard @ 12:53 PM
    Contact this user
    Does anyone make a mini-split with 8 indoor units and 1 each 4-ton heat pump unit, 3-phase?  Thanks!
  • RobG RobG @ 1:55 PM
    Contact this user
    Not Sure?
    I'm not sure that I fully understand you question. You might check out Mitsubishi City Multi though.
    Rob
  • bob bob @ 4:37 PM
    Contact this user
    fujitsu
    google fujitsu general
    bob
  • paul paul @ 4:57 PM
    Contact this user
    mini split
    check the mitusbishi city multi i don't think that it will go down to 4 ton, in the
    460 volt 3 phase. i believe the smallest is 6 ton. or is your voltage 208/230 3 phase
  • paul paul @ 5:02 PM
    Contact this user
    mini split
    the mitusubishi city multi that i looked at are the R-2 series and the Y series
    the H2i Y series also the S series but it is not 3 phase that i could check
