The Wall
Forum / Radiant Heating / Indoor outdoor reset vs other valves
  • Post a Reply to this Thread
    Indoor outdoor reset vs other valves (5 Posts)
  • Rascal Rascal @ 10:24 AM
    Contact this user
    My plumber wants us to change from our current type valve (starts with T) to an indoor outdoor reset. We have high temps in the house over 82 degrees and thermostats are set at 64 but furnace continues to run and circulate in the house causing extreme heat and extreme propane bills. The domestic hot water circulator and primary circulator are pushing against the point with no pressure change sucking hot water through the home zone causing the system to run continuously. The broiler system is Burnham.
  • SWEI SWEI @ 11:14 AM
    Contact this user
    valve type
    is a small part of the picture.  Do you have a piping diagram or some photos you could share?
  • KCA KCA @ 2:34 PM
    Contact this user
    I think that he's saying
    that there are two circulators that are conected in series and that thay are pumping into the point of no pressure change....  (Expansion tank)....  The two circs in series doubles the head and since they can't pump past the PONPC they pull through the zone valves and cause a ghost flow.. So while they are away.... Everytime the domestic water (Side Arm) comes on heat is being applied to the floors of the home ... overheating the home to 82degF +-... The system isn't piped now in a primary / secondary  arangement so the Plumber is suggesting to pipe the system in that manner using close tees and outdoor reset...
    Is that about right?
    This post was edited by an admin on April 21, 2013 2:38 PM.
  • unclejohn unclejohn @ 5:54 PM
    Contact this user
    First off you
    Need a new plumber. While a outdoor reset control may be a good idea, it most definitely won't solve your problem of the system running continuously
  • KCA KCA @ 6:07 PM
    Contact this user
    I don't believe that
    the system runs continuosly.... I believe that there is Ghost Flow... That's why he is considering re-piping in a Primary / Secondary arangement... and while he is doing that... he is going to add reset...
    So the HO is just asking for verification on whether reset is a good idea and whether re-piping is a good idea.. At least that is what I can get from it...
