The Wall
Forum / THE MAIN WALL / Check valve position
  • Post a Reply to this Thread
    Check valve position (3 Posts)
  • hrlevy hrlevy @ 8:34 PM
    Contact this user
    I am installing a laundry tub pump for washing machine to drain into. I was wondering if the check valve can be installed horizontally or does it need to put vertically. All the instructions say is to install near to pump.
    thank you.
  • jonny88 jonny88 @ 8:56 PM
    Contact this user
    check valve
    on a 45 degree is best
  • Jamie Hall Jamie Hall @ 9:39 PM
    Contact this user
    but if you can't do that
    a regular swing check should -- in my view -- always be installed so that the flow through it is horizontal or upwards -- never downwards.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
