The Wall
Forum / Carbon Monoxide Awareness / Draft hood retrofit on standing pilot appliances?
  • Post a Reply to this Thread
    Draft hood retrofit on standing pilot appliances? (5 Posts)
  • SWEI SWEI @ 10:02 AM
    Contact this user
    After reading that Minnesota report on tankless water heaters and considering the reports here of fuel savings with barometric damper retrofits, I'm thinking that applying these to existing tank style gas-fired water heaters might be able to demonstrate reasonable ROI while increasing occupant safety.
    I'm planning to take one of Jim Davis' CO seminars next time he offers it in Phoenix, but am curious about the inclusion of spill switches on the MG-1 on standing pilot water heaters.  How?
    thanks~
  • SWEI SWEI @ 2:04 PM
    Contact this user
    think I found it
    Field Controls sells a thermocouple adapter (TCA-1) that will work with older (non-FVIR) heaters.
    Anyone done this and have fuel savings numbers to share?
    thanks~
  • Jim Davis Jim Davis @ 8:51 AM
    Contact this user
    Barometric Water Heater Savings
    Sometimes there is not always savings on a residential water because there are no adjustments.  However, depending on how the drafthood was performing there can be.  Sometimes the drafthood acts like its not even there.and over vents.  The thing here is safety and wear and tear on the water heater.  Safety being #1.  Water heaters lead the nation in CO poisonings although they are rarely recognized until someone dies.
  • SWEI SWEI @ 9:29 AM
    Contact this user
    no adjustments
    adjusting fuel and air, or is it something else?
    thanks, Jim.
  • Jim Davis Jim Davis @ 8:28 AM
    Contact this user
    No Adjustments
    Most water heater gas valves have a fixed, non-adjustable gas valve.  The barometric controls air so that it is stable under all conditions.
