The Wall
Forum / THE MAIN WALL / Honeywell Mixing Valve
  • Post a Reply to this Thread
    Honeywell Mixing Valve (7 Posts)
  • Honeywell Mixing Valve
    I like the new Honeywell DirectConnect mixing valve kits.  A real time saver!
    Often wrong, never in doubt.
  • SWEI SWEI @ 11:57 AM
    Contact this user
    clever design
    are they competitively priced?
  • bill bill @ 12:19 PM
    Contact this user
    And...
    I looked and could not find any. Can you come up with some literature?
  • hot rod hot rod @ 4:12 PM
    Contact this user
    clever idea
    is that a low lead valve that California requires now a days?
  • HWHydronics HWHydronics @ 2:37 PM
    Contact this user
    LF Version Available - AMX300TLF
    There is a LF model available (AMX300TLF)
  • heatpro02920 heatpro02920 @ 4:25 PM
    Contact this user
    I can't believe
    this is on here, I bought one yesterday for a customer, my tech installed it today, and I was waiting to hear back from him when he comes in at 5:30 to see how it worked out.... I couldn't believe my cost was under $85!!! If my guy says it was as easy as it looks Im going to stock them, these are a great idea....
    I have a customer that has a radiant heating system running off of a condensing water heater and it has no mixing valve it is just set low {like 95*} but it runs out of heat pretty fast, so I was going to have my guys install a mixing valve this summer for him, this may work perfectly for that...
    This post was edited by an admin on May 1, 2013 4:31 PM.
  • Plus
    they give you two extra ports - one for unmixed hot water (laundry, dishwasher, radiant to a heat exchanger, etc.) and another port for a recirculation loop return.
    I saw this display on my suppliers counter on my way to the job where I needed one and even though I had two conventional mixing valves, I bought one for speed.
    Here is the literature:
    http://www.forwardthinking.honeywell.com/related_links/water/amx_300/install/62_3112.pdf
