The Wall
Forum / THE MAIN WALL / Power Gas Conversion Burners
  • Post a Reply to this Thread
    Power Gas Conversion Burners (15 Posts)
  • Tim McElwain Tim McElwain @ 12:20 PM
    Contact this user
    should they be done away with? It is estimated that 98% of plumbing and heating contractors would not install them. Some interesting rumors about them are:
    1. Efficiency only around 70%
    2. Gas will rot the oil boiler firebox
    3. They require a special stainless steel liner very expensive
    4. Most Authorities Having Jurisdiction do not approve them
    5. Most boiler manufacturers will void the warranty on the equipment
    7. They make very high levels of carbon monoxide
    The list goes on, and on and on!
    Well I am getting 20 to 30 phone calls/e-mails a week from homeowners looking for someone to install one on their fairly new oil boilers. Anyone interested in this work contact me and give me your location and phone number and I will refer them to you.
  • Eastman Eastman @ 1:29 PM
    Contact this user
    Is this similar to
    the project MarkS detailed about a week ago?
    Why would gas rot an oil firebox?
  • SWEI SWEI @ 3:41 PM
    Contact this user
    Voided warranties
    doesn't Magnusson-Moss come into play here?
  • Steamhead Steamhead @ 4:04 PM
    Contact this user
    Gotta wonder
    who is spreading these rumors.......
    And if you get any calls for the Baltimore area, you know where to send them ;-)
  • JStar JStar @ 5:33 PM
    Contact this user
    Burners
    I find that the companies who do not install them correctly, and have no idea how to make them run efficiently, perpetuate these rumors so that they can sell entire systems. There is a direct correlation between a technician who bad mouths conversion burners and a technician without a combustion analyzer.
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • Tim McElwain Tim McElwain @ 7:27 PM
    Contact this user
    These are some of the
    things homeowners are being told when they inquire about converting.
    Have also had some mechanical inspectors who state that conversion burners are not authorized unless listed in the I and O manual for the boiler. If not listed then third party testing will be required. They state they have never heard of Z21.8. I am telling installers to refer them to the conversion burner company whose burner they are installing.
  • Charlie from wmass Charlie from wmass @ 8:04 PM
    Contact this user
    I have been told,
    not reliably, that MA requires a non universal burner tube. It needs to be a welded air tube for that specific boiler. I have not found this in writing yet. As for liners I often find the people need liners and they need SS because they want the option to go back to oil some day. The chimney needs a liner no matter what burner or boiler is used.
    cell # 413-841-6726
  • Steamhead Steamhead @ 11:54 PM
    Contact this user
    A SS liner
    is the only thing to use in a chimney that used to serve a coal- or oil-fired unit. Residual sulfur will eat up an aluminum liner quickly, no matter how well the chimney is cleaned.
  • Charlie from wmass Charlie from wmass @ 8:06 PM
    Contact this user
    as for efficiency being 70%
    I have a conversion on a H.B. Smith 101 snowman and I am getting 70% efficiency.
    cell # 413-841-6726
  • jscola jscola @ 8:07 PM
    Contact this user
    conversion burners
    Hello,
    I've done about 2 dozen Carlin conversion burners in the portland and Midcoast maine area.
    My company is Doghouse energy services, located in Freeport Me and I can be reached @ info@doghouseheating.com
    Thanks
    John Scola
  • Eastman Eastman @ 9:01 PM
    Contact this user
    Why
    is the efficiency less?
  • Charlie from wmass Charlie from wmass @ 10:37 AM
    Contact this user
    The efficiency is 70%
    because it is a 1910 coal boiler. Kind of a miracle to get that out of it. My point is the newer tighter boilers should do much better than that.
    cell # 413-841-6726
  • Steamhead Steamhead @ 11:51 PM
    Contact this user
    On a snowman
    a.k.a. an old round coal-converted boiler, 70% is pretty good. Obviously it would be much better on a newer model.
  • Tim McElwain Tim McElwain @ 1:15 PM
    Contact this user
    Charlie, I have
    had some of those in the past with proper baffling and sealing them up real tight with total control over excess air to give 75% and a few dry base with a combustion chamber being built and using an Economite E-20 burner to get 78% and even 80% on a few.
  • tim smith tim smith @ 8:15 AM
    Contact this user
    Re CBs and efficiency etc
    We have done 100s of CBs over the years since the 1960s. Generally our combustion efficiency will be in excess of 78% and many times over 80. Old pot belly boilers, firetubes, cast iron sectionals etc. Reality is the thermal efficiency is probably only 70% on these pre 1970s boilers.  On modern day boilers we do check with the mfr to see if there has been any testing with gas guns. If not we tend to shy away due to liability. We still repair e20s, ds 20s, ds22s, F400s and 800s. Parts have become scarce for the old Economites but we come up with replacement boards through Robertshaw. Always a challenge these days although with mfr support having gone away on the old burners.  Just my .02 worth on this subject.  Tim
