The Wall
Forum / Radiant Heating / low water cut-off
  • Post a Reply to this Thread
    low water cut-off (6 Posts)
  • PDB2 PDB2 @ 2:55 PM
    Contact this user
    low water cut-off
    I want to install a LWCO (none on it now) on my Weil Mclain CGa spark piloted boiler, but unsure as to using a 24v or 120v type. What would I need to be considering to decide which one to order? Any brand recommendation?
  • RJ RJ @ 4:37 PM
    Contact this user
    lwco
    Curious, what boiler/mechanical inspector allowed this install without one.
    RJ
  • Zman Zman @ 5:52 PM
    Contact this user
    LWCO
    There are plenty of places where LWCO's are not required on residential jobs.
    Both 120 volt and 24volt accomplish the same thing. Unless code dictates, use whichever is easier for your install.
    Carl
  • RJ RJ @ 3:27 PM
    Contact this user
    lwco
    that scares me, residential should have the same or tighter code requiements in your area
    RJ
  • RJ RJ @ 3:29 PM
    Contact this user
    lwco
    sorry I meant the same or tighter as commercial
    RJ
  • Zman Zman @ 8:58 PM
    Contact this user
    It depends
    Does a mod/com located in a basement need one? You generally have a water pressure safety. Supply and return sensor plus a high limit on the boiler and a T&P.
    Is that enough?
    Carl
    An old school cast Iron is a different animal.
