The Wall
Forum / THE MAIN WALL / pex or copper in concrete?
  • Post a Reply to this Thread
    pex or copper in concrete? (9 Posts)
  • tonyk tonyk @ 8:52 PM
    Contact this user
    Hello,
    I have a boiler with base board heat. There is a  4 ft. piece of copper pipe which is buried in the the concrete slab in the area under my front door. It has developed a  leak and I was wondering if it is better to use Pex or stick with the copper.  I will be recovering the pipe with concrete when the leak is repaired.
    Also, if I use pex are Shark Bite fittings a good way to connect to the existing copper pipe.
  • Gordy Gordy @ 9:31 PM
    Contact this user
    Pex
    In concrete is better. All though copper lasts a long time, pex will outlast copper with the use of fly ash, and other chemicals in today's concrete mix its hard on copper.
  • Steve Whitbeck Steve Whitbeck @ 10:07 PM
    Contact this user
    PEX
    PEX is better but for a short run just run the copper pipe inside a rubber hose to keep it off the concrete. That way you don't have to buy any special connectors.
  • tonyk tonyk @ 10:16 AM
    Contact this user
    Pex or copper
    If I use pex, or copper should I cover it with a hose? or I was thinking about using pipe insulation or some kind of foam wrap to allow for expansion and to insulate it from the concrete
  • hot rod hot rod @ 10:46 AM
    Contact this user
    pipe wrap tape
    would be fine, insulation would give you a hollow space in the concrete.
    Most plumbing and HVAC suppliers have this tape.
  • Ironman Ironman @ 11:23 AM
    Contact this user
    Shark Bites...
    May be okay if the copper is clean and not out of round. Personally, I wouldn't do it. I'd go with the appropriate press fittings. Pex moves form thermal expansion and contraction and may cause an issue with the O ring in the long term.
    If it were accessible, that would be a different scenario, but considering the possible cost of redoing it, I'd go with a proven method. If you don't have the tools, you may want to hire a pro.
    Also, make sure that you use o2 barrier pex. It does make a difference.
    Bob Boan
  • Paul48 Paul48 @ 12:44 PM
    Contact this user
    Pex & Connections
    No buried connections.
  • tonyk tonyk @ 4:30 PM
    Contact this user
    Type L copper
    If I use copper, I was thinking about using coil that way no joints under concrete. If I go that route, would type L be OK? or would I have to use type K
  • Steve Whitbeck Steve Whitbeck @ 12:25 AM
    Contact this user
    Use L
    L would be just fine.
    I remove old leaking piping and install new L copper pipe. I insulate the pipe where it may contact the concrete.
