The Wall
Forum / Domestic Hot Water / When tenants call for hot water, the gas boiler makes steam ..outside temp 70
  • Post a Reply to this Thread
    When tenants call for hot water, the gas boiler makes steam ..outside temp 70 (3 Posts)
  • Tomas1 Tomas1 @ 10:33 AM
    Contact this user
    Just had new gas boiler installed for apt house.. When a tenant turns on hot water, I noticed that the radiator return pipes in basement are hot...also the hallway radiator riser is hot. Also, the tenant on first floor is running her AC unit! What is going on. Also note that the building uses a Heat Timer for temp regulation.
  • STEVEusaPA STEVEusaPA @ 2:06 PM
    Contact this user
    uh............
    call back the original installer.......stat!
    You got big, but easily fixable problems
    steve
    Contact this user
    uh............
    steve
