The Wall
Forum / Radiant Heating / Rehau Rauplate
  • Post a Reply to this Thread
    Rehau Rauplate (1 Post)
  • SpeyFitter SpeyFitter @ 11:47 AM
    Contact this user
    Rehau Rauplate
    I'm just wondering if anyone has tried Rehau Rauplate for an in the joist space tube and plate installation of O2 barrier pex? The problem with some traditional heat transfer plates is they seem to cause squeeking with some of the oxygen barriers used of oxygen barrier pex such as the Rehau raupex. The Rehau rauplate is a different configuration of heat transfer plate that to me looks like it will work better at allowing the pex to move a little bit as it expands without constraining it like conventional u style heat transfer plates.
    Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
