The Wall
Forum / A-C, Heat Pumps & Refrigeration / How critical is this new 410a flare
  • Post a Reply to this Thread
    How critical is this new 410a flare (9 Posts)
  • TonyS TonyS @ 5:02 PM
    Contact this user
    I have an older yellow jacket deluxe flare tool that I have been using for many years.
    I can honestly say I have never had a leak in one of my flares. But I keep hearing that you must use the new deluxe flaring tool on the new mini splits.
    I have even taken my older unit to the supplier and made a flare with mine and then with their newer unit. I am really hard pressed to see a difference in the two.
    What is the difference between the Two and how critical is this? Who here has already purchased the new tool and can really attest to it working better?
    http://www.yellowjacket.com/product/854
  • JStar JStar @ 8:00 PM
    Contact this user
    Flare
    I've recently bought this model flaring tool after suffering through numerous cheap versions. It works very well, with absolutely no flaws so far. Does it make a better, 410A friendly flare? Yes, no, I don't know? A flare is a flare is a flare. As long as it is leak proof, it will work.
    - Joe Starosielec
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • TonyS TonyS @ 8:51 PM
    Contact this user
    this is the model I have now
    http://www.ebay.com/itm/YELLOW-JACKET-60280-FLARING-TOOL-HVAC-/130917225304?pt=LH_DefaultDomain_0&hash=item1e7b465358
    I agree it is an excellent tool, I just want to know what is the difference between this and the new one. Cant seem to get a clear answer on this.
  • alotlikeearl alotlikeearl @ 1:48 PM
    Contact this user
    Yes!
    Our company has found it does make a differencs.  I would not have thought it would, but it does.
                                   Jerry
  • TonyS TonyS @ 4:19 PM
    Contact this user
    Thanks
    I guess Ill let go of the hundred bucks.
  • radmix radmix @ 7:44 AM
    Contact this user
    Flare
    In the install manual they also require you to use refrigerant lubricant on all of the flair fittings. I just installed 5 heads on one project and 4 on another, used refrigerant lubricant on all flairs and didn't have on leak.
  • Techman Techman @ 10:59 PM
    Contact this user
    New flare.
    OK so what is the difference between the two flares or is it a bunch of smoke? Do both pieces of copper stick out of the flare block the same ? The angle is the same! Is there a "special " flare nut for that special flare? I wonder!
    This post was edited by an admin on June 24, 2013 11:07 PM.
  • alotlikeearl alotlikeearl @ 7:09 AM
    Contact this user
    Not Smoke & Mirrors
    Techman,
    See the "Flare Info PDF" above.  Not smoke & mirrors.  We learned the hard way!
              Jerry
  • Techman Techman @ 8:51 PM
    Contact this user
    New flare
    Me alotlikeearl too ! I was jesting, sorry. Daikin taught that way back ,when they 1st came out. The flare is indeed "deeper" .
