The Wall
Forum / Oil Heating / Backwashing domestic tankless coil
  • Post a Reply to this Thread
    Backwashing domestic tankless coil (7 Posts)
  • HydroNiCK HydroNiCK @ 5:36 PM
    Contact this user
    Hello everyone and Hi Ken Resnick,
    I was recently bonding with my parents boiler and noticed there is a loop installed to backwash the coil.  How do I go about doing this?  The coil is 20 years old and I'm still getting sufficient hot water from it.  However, since i'm fascinated by heating and would like to practice my skills, and can't leave well enough alone... I am thinking about back washing it.  Now, I know how to backwash the coil with cold water but How do I do it with chemical?  I searched the wall so please forgive me if this topic already exists (I have a feeling it does)  please link me to it or provide the proper key words I should search ( I tried "backwash coil").  Also, feel free to let me know that i'm an idiot for contemplating using chemical on a coil that still works well.  However even if i don't use the chemical I still would like to know how to run it through.  Could I tie in a tee with a ball valve and male adapter so i could then hook a hose and pump up to the coil?  I would stick the suction end of the pump into the bucket of chemical.  Hook a hose up to the boiler drain on the loop to drain the chemical coming out of the hot side into a bucket therefore recirculating the chemical through my pump back through the coil?
    Thanks,
    Nick
  • SWEI SWEI @ 1:11 AM
    Contact this user
    Bonding with a boiler
    sounds a bit ephemeral to me, but you might try flushing coil' on http://www.heatinghelp.com/forum/search
    Generally speaking, you recirculate treated water (almost always moderately acidic) through the piping or coil until it is free of deposits.  There are subtleties to the process depending on pipe/coil material(s), the deposited materials, and local water conditions.
  • HydroNiCK HydroNiCK @ 9:34 AM
    Contact this user
    Thanks
    Thanks SWEI
  • billtwocase billtwocase @ 9:28 PM
    Contact this user
    if it's not broken
    don't fix it. You could wind up with a pin hole or two. If you have any doubts, or having issues with hot water, replace it. Years ago acid flushing was done regularly. A lot of coils plugged, leaked, potential health hazard, etc. I know of no one who would take that chance today
  • Steve Steve @ 9:04 PM
    Contact this user
    coil flushing
    many years ago, i acid  washed / flushed   many coils....success rate was  about  30 %....i would not try today  because of  possible  health issues if  acid not fully flushed out....  replace the coil, or take to a radiator shop, & have them soak it in a cleaning tank for at least  4  to 6 hours....../    my  $.05    opinion...
  • heatpro02920 heatpro02920 @ 11:43 PM
    Contact this user
    I agree
    With the others, if its not broke leave it alone, how water is fine, you want to do something flush it really good, but I wouldn't go running stuff through it and disturbing too much...
    You could end up bonding with some pretty stubborn tankless bolts..
    This post was edited by an admin on August 5, 2013 11:43 PM.
  • Charlie from wmass Charlie from wmass @ 12:39 AM
    Contact this user
    being a steam guy
    I steam clean the coils I deal with during the annual service.
    cell # 413-841-6726
