The Wall
Forum / Gas Heating / possible gas conversion and selling equipment
  • Post a Reply to this Thread
    possible gas conversion and selling equipment (6 Posts)
  • conversion conversion @ 12:56 AM
    Contact this user
    Hello,
    I need help calculating the payback costs if it makes sense to convert to natural gas.
    My current equipment is about 5 years old; 3 stage 85% efficiency rating, Riello burner, well insulated indirect and outdoor reset. Over the past 5 years my average annual oil consumption average has been 330 gallons per year. This coming winter I expect to use less fuel after I insulate some key areas of my home.
    I know there is more energy from oil compared to an equivalent amount of gas and since I use relative small amounts of fuel, converting to gas may not make financial sense
    Depending on the payback, perhaps just a gas burner makes sense with my current boiler.
    any suggestions on who might be interested in purchasing a 4 year old burner and possibly boiler, well maintained annually? I do not want to invest too much time and effort and trying to sell either. THANKS!
  • BobC BobC @ 7:31 AM
    Contact this user
    It will take time but it will pay back
    I replaced a 16 year old oil fired Burnham v75 steam boiler because the oil tank was beginning to weep, my fuel use was about 370 gallons per year. I had a smith 8-3 installed with a Carlin EZgas gas gun installed last October. I used 432 therms of gas for this last seasons heating. Gas in my area is about $1.45 per therm so my savings for the year was about 50% compared to what I would have paid for oil.
    In my case it will take 11-12 years for the fuel savings to pay for the new boiler. You use less oil than I did so IF you can just put a gas gun into your current system payback would be less. If you have to replace everything, your payback will be longer.
    I'll warn you up front that the Carlin EZgas is noisier than the oil gun in my smith 8-3 boiler (low frequency rumbling). What do you have installed now and can you post some pictures?
    Bob
    Smith G8-3 with EZ Gas @76,700 BTU, Single pipe steam
    3PSI gauge
  • conversion conversion @ 11:13 PM
    Contact this user
    I have a Riello burner. I was told Riello's are one of the best and most reliable.
    Biasi B10 boiler
    Triangle Tube indirect
  • earl burnermann earl burnermann @ 6:44 AM
    Contact this user
    conversion formula
    Here is a way to figure out how much you will save on heating your home with gas:
    gallons of oil consumed X 1.4 X price per therm of natural gas
    price of oil consumed - result of above
    The btu rating of oil is rounded to 140,000 for this formula. A therm of gas is 100,000 btus
    If the women don't find you handsome, they should at least find you handy!
    This post was edited by an admin on June 9, 2013 6:47 AM.
  • Steamhead Steamhead @ 10:28 AM
    Contact this user
    The Biasi B10 series boilers
    are available from QHT with either Carlin or Riello gas burners. Either unit will run well in your boiler- there's no need to replace the boiler to switch fuels.
  • Aaron_in_Maine Aaron_in_Maine @ 1:53 PM
    Contact this user
    Gas burner
    I would put in either burner. If one is more abundant in your area I would lean that way. Service will be easier to find. The Riello will run a little more money than the carlin.
