The Wall
Forum / A-C, Heat Pumps & Refrigeration / Heat Pump Water Heater and Humidity
  • Post a Reply to this Thread
    Heat Pump Water Heater and Humidity (8 Posts)
  • Solid_Fuel_Man Solid_Fuel_Man @ 9:29 PM
    Contact this user
    Wondering how RH effects the COP of HPWH.  I'm installing an add-on unit (Geyser) and want to duct it into the living space, for summer cooling.  The master bath is directly above the mechanical room, how will this potential high humidity effect the evaporator's ability to absorb heat from the air?  I was thinking this would be better?
    Taylor
    Always keep learning: observing what works, and what doesn't. Ask questions
  • John Mills John Mills @ 2:55 PM
    Contact this user
    Humidity is heat
    Latent heat. So the more humid the air into the heat pump, the more capacity.
  • John Mills John Mills @ 2:58 PM
    Contact this user
    BTW
    But, are you sucking air out of the bathroom or blowing cold air into it? If blowing in, where does the air come from? If mechanical room, is there any fuel appliances in it?
  • Solid_Fuel_Man Solid_Fuel_Man @ 10:47 AM
    Contact this user
    Pulling air from bathroom
    and ducting it to the master bedroom, which is on the other side of the partition.  Basically the unit will be in the mechanical room below the floor, pulling air from bath high in partition wall and them pushing the cooler air into bed via floor register.
    I figured the humidity was latent heat as the phase change would condense the water out and yealdmore heat driving the COP up.  We in this part of the country are just beginning to get into HP tech, so I want to have learn as much as I can.  Install as well and efficient as possible
    Thank you!
    Taylor
  • John Mills John Mills @ 12:20 PM
    Contact this user
    Wow
    That's going to be an interesting smelling bedroom at times
  • Solid_Fuel_Man Solid_Fuel_Man @ 5:50 PM
    Contact this user
    Stink ducting.........
    Nah, I only stink up the 1/2 bath downstairs.  That bath is for showering and going #1 only for me. LOL
  • John Mills John Mills @ 12:03 PM
    Contact this user
    Solid fuel
    So the solid fuel stays downstairs, huh?
  • Solid_Fuel_Man Solid_Fuel_Man @ 7:20 PM
    Contact this user
    Not that type of fuel..........
    Haha, biomass is my game.
