The Wall
Forum / THE MAIN WALL / Water source heat pump loop and hot water system
  • Post a Reply to this Thread
    Water source heat pump loop and hot water system (3 Posts)
  • Chuck Chuck @ 3:25 PM
    Contact this user
    Water Source heat pump system – I have used a boiler for direct heat add (boiler used only for heat add). I have used a boiler for an indirect heat add (heat exchanger). I don’t think I had a system the hot water system was directly coupled to the heat pump loop (hot water used for entry unit heaters and heating ventilation air). I can’t think of any reason I can’t have the loops directly coupled as long as I have a heat trap. Am I not thinking of something?
    (I am talking about a regular water source heat pump loop - not a ground source).
  • JStar JStar @ 7:38 AM
    Contact this user
    Wshp
    If the cooling side of the system is an open tower, the constantly added fresh water can destroy the piping/boiler. I would keep the boiler on its own set of piping, whether a direct add or heat exchanger.
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • Chuck Chuck @ 9:39 AM
    Contact this user
    Closed loop.
    Closed circuit cooler. Closed system. I haven't tried to lay it out but the trick part is where to put the expansion tank.
