The Wall
Forum / THE MAIN WALL / new hotwater system
  • Post a Reply to this Thread
    new hotwater system (5 Posts)
  • wildmangreen wildmangreen @ 10:49 AM
    Contact this user
    new hotwater system
    got a charmaster indoor woodfired water boiler and storage tank plus a water to water heat exchanger coming soon...
    want to know about hooking this system up to a series of pex radiant heat tubes and a few cast iron radiators...
    can anyone tell me what sort of plumbing etc. is involved here?
  • Paul Pollets Paul Pollets @ 11:16 AM
    Contact this user
    Shopping
    There's a lot of info required to make the hookups, not to mention technical skill and expertise. You'd do best to find a local pro who knows how to assemble the mechanicals without creating numerous safety hazards.
  • wildmangreen wildmangreen @ 3:02 PM
    Contact this user
    thanks
    that was really helpful.
  • Jamie Hall Jamie Hall @ 7:43 PM
    Contact this user
    I am quite sure,
    knowing Paul, that he meant no disrespect.  However, unfortunately, he's right.  Without knowing -- quite exactly -- what the heat losses in the spaces to be heated are, how much radiant tubing is involved and how it is arranged, how big the radiators are and where they are located (for example: are they all in the same space?), what the heat output of the boiler is, how tall the building is -- and a host of other factors! -- it would be impossible for anyone to answer your question.
    One could start off by simply saying something about at least two pumps, several controls, several powered valves, probably two expansion tanks, etc. etc. -- but that isn't much help either, is it?
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • SWEI SWEI @ 7:52 PM
    Contact this user
    Assuming you want to pipe it yourself
    I'd still consider hiring an experienced designer.
    You could start by reading this http://www.caleffi.us/en_US/caleffi/Details/Magazines/pdf/idronics_10_us.pdf
