The Wall
Forum / Radiant Heating / Radiant tubing and toilet wax seal
  • Post a Reply to this Thread
    Radiant tubing and toilet wax seal (7 Posts)
  • BigErl BigErl @ 6:41 PM
    Contact this user
    Hello everyone. I'm putting radiant in a bathroom floor using uponor quik trak panels and the 5/16" tubing. Is there a minimum distance I should keep between the tubing and toilet wax seal?
  • Gordy Gordy @ 9:25 PM
    Contact this user
    Rubber Seal
    instead of wax no worries otherwise yes 8-12 "
  • BigErl BigErl @ 11:53 PM
    Contact this user
    Thanks
    Thanks Gordy
  • zacmobile zacmobile @ 2:10 PM
    Contact this user
    I wouldn't worry.
    Over the years I've had many people bring this up but I've left wax seals on my dash before in the summer and they don't get significantly deformed and that is way hotter than any radiant floor would get. I think the floor would be uncomfortable to walk on before it would be a danger to the wax seal.
  • Charlie from wmass Charlie from wmass @ 12:40 PM
    Contact this user
    12" is what I do
    keeps the tubes out near where your feet are anyways. I have seen wax rings that over time flowed out of place with the radiant too close. Then I used the foam rubber rings to replace them.
    cell # 413-841-6726
  • GermanPlumber GermanPlumber @ 6:56 AM
    Contact this user
    Wax free seal
    I would use a wax free seal anyhow !
  • hot rod hot rod @ 10:46 PM
    Contact this user
    Fernco
    is the best waxless seal I have used. Deep boot and a tight fit even inside scaled cast iron pipe.
