The Wall
Forum / Radiant Heating / Radiant - Gypcreet
  • Post a Reply to this Thread
    Radiant - Gypcreet (4 Posts)
  • KCA KCA @ 1:54 AM
    Contact this user
    Radiant - Gypcreet
    Hello...
      What are you guys using for insulation when you have a Radiant staple down and Gypcreet over.   I can't put any insulation in the joist cavity below & I feel like I need some...  Have you been using a Bubble wrap / reflective insulation and staple to it?
       Thanks for your help
      :-)  Ken
  • SWEI SWEI @ 9:33 AM
    Contact this user
    Joist cavity below
    Why not?
  • Zman Zman @ 9:54 AM
    Contact this user
    Warm Board
    Ken,
    I am guessing you have finished ceiling below. Can you blow in insulation?
    First off  bubble wrap will not work in a radiant system. The "reflective" value only works in an air space. Even then it is suspect and not allowed by most codes. The other thing to look at is the compressive rating. If the product will compress under load, the gyp will crack. If you can afford the space rigid insulation would work.
    Why are you looking for a high mass system? I would take a hard look at a product like warm board. You can put rigid insulation under it and eliminate the thermal "flywheel effect"
    Carl
  • Gordy Gordy @ 4:15 PM
    Contact this user
    Zman
    X2
    If headroom is an issue fan fold before bubble wrap. R1 is 100% better than r0. Or bubble wrap.
