The Wall
Forum / THE MAIN WALL / Help me choose system for midsize new england house
  • Post a Reply to this Thread
    Help me choose system for midsize new england house (4 Posts)
  • Rekonn Rekonn @ 11:30 PM
    Contact this user
    Hello, which of these two systems would you choose? I have a 2100 sqft 2 floor house built in 1928 with attic and basement in Arlington MA. I've had two contractors do manual J calculations, both came up with ~66k heating btu load. I plan to finish the basement (~900sqft) in the next year or two. Both options are very similar in price, so that's not really a factor.
    System 1: AC + hydro air
    First floor:
    2.5 ton Carrier FV4CNF002 fan coil with ECM motor AHRI #3657139 and hot water coil in basement
    Second floor:
    2 ton Carrier FV4CNF002 fan coil with ECM motor AHRI #3657138 and hot water coil in attic
    Two condensing units installed outside on plastic pad, Carrier 24ACC630A and Carrier 24ACC624A
    Buderus GB142-30 condensing gas boiler, 96% AFUE
    reuse existing indirect water heater
    save cast iron baseray baseboards currently on first floor for when basement eventually finished
    System 2: AC + furnace
    First Floor:
    80,000 BTU Trane XV95 Variable speed Furnace, XB14 3 ton Trane condenser, Trane 3 ton coil
    Second Floor:
    60,000 BTU Trane XV95 Variable Speed Furnace, XB14 2 ton Trane condenser, Trane 2 ton coil ( Furnace boxed in attic to keep insulated )
    2410 April Air Filter
    Model 400 April Air humidifier ( basement only)
    Furnace sized for future basement zone
    new 50 gal gas hot water heater
  • JStar JStar @ 6:28 AM
    Contact this user
    House
    What type of system is in the house now?
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • Rekonn Rekonn @ 7:26 AM
    Contact this user
    oil steam
    Currently have steam radiators and baseray baseboards powered by an oil boiler. Also have an Amtrol indirect water heater. If you'd like pics and additional details, you can look at this thread, LINK. I was looking into all options at first, but have since found out my wife is against radiators in general. House now has a gas line.
  • heatpro02920 heatpro02920 @ 12:49 PM
    Contact this user
    If I had to choose I would
    want system number 1, but if I was installing it, it would be a Triangle tube Prestige solo boiler, with first company hydro air units, armstrong condensing units and a rinnai condensing water heater....
    But thats just me... what they are proposing will be a nice system, and I like the Buderus boilers as well...
    Most important thing to keep in mind is choose a contractor that you trust and like what their previous work looks like... Sounds like you got someone good, since they did perform a heat loss calc, that is half the battle...
