The Wall
Forum / A-C, Heat Pumps & Refrigeration / Good vacuum pump for hobby?
  • Post a Reply to this Thread
    Good vacuum pump for hobby? (2 Posts)
  • ChrisJ ChrisJ @ 11:58 AM
    Contact this user
    As some already know refrigeration is a hobby of mine so I don't do it much. I'm in need of a good vacuum pump for occasional use and am curious if anyone could recommend one? I looked at a few made by CPS but don't know where they rank in the scheme of things.
    Also is a digital vacrometer really needed or is the one on most manifold sets good enough? I have a set of Yellowjacket II brute gauges as well as a CPS R134A set.
    My main projects will be refrigerators which have refrigerants that are very sensitive to moisture so a good vacuum is important. I have all the time in the world when doing this so speed isn't an issue but I want a good strong vacuum.
    Thank you for your time and as always all comments are welcome.
    Weil-McLain EG-45 connected to 392sqft of radiation via two 2" risers into a 3" drop header and 2" equalizer. Using Rectorseal Steamaster water treatment to greatly reduce corrosion in the boiler.
    Steam system pictures updated 6/5/14.
    https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
    This post was edited by an admin on June 27, 2013 11:59 AM.
  • ChrisJ ChrisJ @ 1:36 PM
    Contact this user
    Got one
    Decided to go with a Robinair 15600.
