The Wall
Forum / A-C, Heat Pumps & Refrigeration / carlyle o6e compressor failure
  • Post a Reply to this Thread
    carlyle o6e compressor failure (3 Posts)
  • elfie elfie @ 1:34 PM
    Contact this user
    diagnosis for a compressor that needs replacing is that it was mechanically broken up internally. compressor while still operational was vibrating excessively.  the oil pressure switch had been disconnected.
    question is, what lead to compressor failure.
    if oil pressure switch had been connected could it have protected the compressor?  would oil pressure switch being disconnected contribute to a compressor failure?
  • RJ RJ @ 1:41 PM
    Contact this user
    carlyle
    re read all the past posts that were sent to you and follow all recommendations
    RJ
  • David Broome David Broome @ 9:42 PM
    Contact this user
    run nubbie
    if there was a oil pressure switch it should have never been by passed or removed unless done so by the factory. oil return is very critical but more so on commercial equipment
