The Wall
Forum / A-C, Heat Pumps & Refrigeration / carlyle o6e compressor - unloaders replaced
  • Post a Reply to this Thread
    carlyle o6e compressor - unloaders replaced (2 Posts)
  • elfie elfie @ 10:28 AM
    Contact this user
    a compressor was diagnosed and it was found that both unloaders should be replaced.
    this followed a finding that there was excess oil in the sump (there is a need to assess oil in system and recover possible remaining excess oil after removing some).
    what would cause unloaders to need replacement (have heard its unusual to replace unloaders)
    how would a malfunctioning unloader impact compressor operations?
    thanks
  • David Broome David Broome @ 9:34 PM
    Contact this user
    o60e
    the work horse of the semi hermetric compressors. I always replace the unloaders if the compressor is shorted or burnt out. Just a safe thing to do and will save you alot of head aches in the long run
