The Wall
Forum / A-C, Heat Pumps & Refrigeration / 20 yr old residential split system AC compressor
  • Post a Reply to this Thread
    20 yr old residential split system AC compressor (2 Posts)
  • elfie elfie @ 2:01 PM
    Contact this user
    system is working fine and cooling fine.
    there is a thermal protect switch on compressor that shuts if down when it gets to hot in the sun. there are of course fuses to protect from surges.
    my question is - what can be done to ensure that compressor lasts alot longer.  or is it something that really doesnt require anything, and when it decides to die, it dies.
    also, how long does a compressor normally last (used only during summer)
    thanks.
    This post was edited by an admin on July 20, 2013 3:00 PM.
  • drhvac drhvac @ 6:35 AM
    Contact this user
    compressors
    Keeping your coils and filter clean will help your compressor run longer. You should also make sure of all the following:
    tight electrical connections and proper voltage inputs, capacitors are good, proper air flow over evap. coil, proper charge. You may want to install a surge protector for extra protection.
    Properly installed compressors (units) should last over 20 years. AC systems now a days get a bad rap because they are initially installed wrong. Good luck, hopefully you get at leat another 5 yrs.
