The Wall
Forum / Gas Heating / Sizing an Internal Expansion vessel???
  • Post a Reply to this Thread
    Sizing an Internal Expansion vessel??? (2 Posts)
  • tangled in wires tangled in wires @ 7:51 PM
    Contact this user
    Tomorrow I'm installing a Bosch ZBR 35 combi boiler for the first time. I'm just reading through the manual and Its says that that Internal Expansion vessel pre-charge pressure must equal the static system height of the boiler.
    How exactly do I calculate whether or not  I would need to add an on another expansion tank?   I believe I need to find out how many gallons the system holds. Now this being a retrofit that might be tricky. Can anyone point me in the right direction here?
  • kcopp kcopp @ 11:14 PM
    Contact this user
    If you doing....
    a simple system w/ a copper finn tube set up you are prob going to be fine. I might leave a threaded tee on the return to make a way in case you need it.
    You can add a bit of air to the extrol inside if you have abnormal height.
    This post was edited by an admin on July 23, 2013 11:16 PM.
