The Wall
Forum / Radiant Heating / Changing flooring in existing radiant setup.
  • Post a Reply to this Thread
    Changing flooring in existing radiant setup. (5 Posts)
  • sgtmikey sgtmikey @ 8:40 AM
    Contact this user
    We are considering replacing the wood flooring in one area of our home with tile. The room is an extension on the back of a cape: a kitchen, dining, living room. It is a single zone, 3 loop, sandwich install with aluminum plates. 3/4" qs oak covers it now. We were thinking of going with tile laid on 1/2" backer board.
    The attached image shows the floor specs. It is room 1.
    How will this change effect heat loss, or any other aspect of heating? I am in the early stages of a gas conversion. Thanks.
  • Rich Rich @ 6:44 PM
    Contact this user
    Sgt Mikey
    as long as these rooms are presently on the same zone and you are satisfied with the comfort and all are to be changed keeping similar characteristics you will be fine . Your system for these rooms will be a bit more responsive .  You are not changing the Finish floor R value negatively so all should be good .
    You didn't get what you didn't pay for and it will never be what you thought it would
  • mariae mariae @ 8:19 AM
    Contact this user
    Suggest Me
    Hi Rich,
    How do you decide, that it is good? I am planning to change wooden floor of 10x10 kitchen with tile. Other rooms surface has complete wooden floor. What will be my heat loss graph. Sorry, I am completely new with this topic.
    This post was edited by an admin on July 27, 2013 8:20 AM.
  • Rich Rich @ 9:55 AM
    Contact this user
    Chris's
    statement is correct . However when dealing with any heating occupant comfort is key . If the floor surface temp should be uncomfortable (doubt it though) the loop/loops for the kitchen area can be separated at the manifold by adding actuators and a thermostat in kitchen .  Not a terrible remedy , but not worth doing before determining if in fact there is a comfort issue .
  • Chris Chris @ 9:32 AM
    Contact this user
    It Doesn't Change The Heat Loss
    It changes the required water temp needed to overcome the heat loss based on the R-value of the finished floor. Tile has an R-Value of .5, 3/4" oak .68, There will be no effect or such minimal effect that you would then balance off at the manifold.
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
