The Wall
Forum / THE MAIN WALL / Taco x-Pump block, cartridge swapping
  • Post a Reply to this Thread
    Taco x-Pump block, cartridge swapping (3 Posts)
  • Solid_Fuel_Man Solid_Fuel_Man @ 8:23 PM
    Contact this user
    Anyone know if you can change the cartridges to ones of different curves on the XPB?  The sheet states the top and bottom can be switched.  Can I just put a 007 in the top (injection side) for added capacity?
    Thanks all........starting to think about winter already
    Taylor
    Always keep learning: observing what works, and what doesn't. Ask questions
  • Rich Rich @ 8:19 AM
    Contact this user
    Why
    make the injection pump larger ?  I cannot remember which pump is there , 006 or 008 though .  In either case you don't want to inject too much boiler water into the loop . either the 006 will add 2 GPM to your loop at 7.5' , the 008 will give you 2 GPM at 14+' .  The 007 is more of a flat curve than the others . If anything I would say you need a larger system pump , not more injection . I can't think of a situation where you would need to inject more water into your loop , and if you do require more you probably should use other than the RMB or X Block for your needs .
    You didn't get what you didn't pay for and it will never be what you thought it would
    This post was edited by an admin on August 17, 2013 8:21 AM.
  • david sweet david sweet @ 5:51 AM
    Contact this user
    XPB uses 008's
    The Taco X-Pump Block (XPB) uses 2 @ 008 circulators; one variable speed and one fixed speed. Usually the variable speed circulator is used for injection as temperature control and fixed speed is used for system. The XPB is designed for 008 circulators and cannot be substituted for a different model. If more capacity is needed than 2 can be piped in parallel.
