The Wall
Forum / THE MAIN WALL / W/M GV-90+
  • Post a Reply to this Thread
    W/M GV-90+ (6 Posts)
  • Roland Roland @ 9:24 AM
    Contact this user
    W/M GV-90+
    Hi All,
    Came across this Weil-Mclain product. Seems to be a cast iron/stainless steel hybrid, high eff.(91+) boiler.  Any experiance with this?
    http://www.weil-mclain.com/en/assets/pdf/gv90_plus_Brochure.pdf
    Thanks,Roland................
  • Tim McElwain Tim McElwain @ 4:44 PM
    Contact this user
    It is the old Weil-McLain
    GV series Gold Boilers with a heat reclaimer attached for condensing. Much the same thing Burnham did a while back with the Revolution Series II.
    The same controls and operation as the Gold.
  • Robert O'Brien Robert O'Brien @ 7:25 PM
    Contact this user
    90% AFUE
    It's for people who can't or won't understand P/S and modulation. If Weil was my choice,I'd go with the 97
  • gennady gennady @ 8:55 PM
    Contact this user
    90+
    This boiler has no outdoor reset, no modulation.
    Gennady Tsakh
    Absolute Mechanical Co. Inc.
    www.AbsoluteMechanicalCoInc.com
  • Roland Roland @ 9:39 AM
    Contact this user
    GV-90+
    I agree that nothing can beat a properly designed and installed mod/con.
     Looking at the I/O manual, it shows that the GV-90+3 and 4 can be installed without P/S piping while the larger 5 and 6 need to be installed P/S. Diverter T systems may or may not work with the provided system pump.
    Also, outdoor reset is offered as a plug and play option provide that the boiler temp not go below 140*F.
    I don't work for W/M and have no financial interest. It just looked to me as a possible alternative to a full-on mod/con system.
    Roland............
  • Tom Tom @ 7:20 AM
    Contact this user
    Dollars and sense
    I think the GV 90+ has its place on the market. It makes sense on baseboard systems, it's rather small btu load and its proven reliability make it good for many applications. Paired with a good condensing on demand helps your bottom line since the boiler is economical. The draw back is I forgot how heavy these cast iron boilers are. I do feel getting 91-2% all the time whenever it runs is good, especially when you subtract all the possible service calls we ALL get with mod cons.
