The Wall
Forum / THE MAIN WALL / This is to good not to share!!
  • Post a Reply to this Thread
    This is to good not to share!! (7 Posts)
  • Harvey Ramer Harvey Ramer @ 2:26 PM
    Contact this user
    I ran across this attemp at stopping a leak on an 410A AC system that I got called out to repair. As Dan would say, this is evidence that a knucklehead was here.
  • Rich Rich @ 6:01 PM
    Contact this user
    SWEET
    Git er done . LMAO
    You didn't get what you didn't pay for and it will never be what you thought it would
  • Gordy Gordy @ 6:52 PM
    Contact this user
    Duct tape
    Probably comes in copper color now!
  • JStar JStar @ 8:17 PM
    Contact this user
    Leak
    Maybe it was better that the person DIDN'T use a torch.
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • unclejohn unclejohn @ 10:33 PM
    Contact this user
    You mean
    That didn't work?
  • R Mannino R Mannino @ 10:40 PM
    Contact this user
    Where's
    the WD 40 can?
  • Harvey Ramer Harvey Ramer @ 11:32 PM
    Contact this user
    Oh it gets better!
    There was no leak at the duct tape location. I found a leak in the Schrader core valves. Whether it made it through the brass service valve caps, i'm not sure.
    When I arrived at the site, the unit was going off on high head. Apparently it was cycling like this "on and off every few seconds" for at least a day or two. I pulled probably a pint of dye out of the system. There were noncondensables in the system and 2 lbs. excess refrigerant. Apparently this knucklehead was determined to find a leak. He cut a slit in the armoflex a ways down the lineset and poured dye in there. The dye was then dripping off the pipe right at the coil connection and he told the home owner; look, it's leaking right there, you are lucky you didn't loose it all. His prognosis was that she needs to have the coil replaced.
    This guy is either dumber than a box of rocks or a knucklehead or both at the same time with a little bit of "you know what" mixed in. The home owner is a sweet elderly lady who just loves everyone and believes anything she is told. I have not seen anything like this before and while I'm giving the benefit of doubt and trying to find logic in what I see, there is none here.
    Scary huh! They are out there.
