The Wall
Forum / Domestic Hot Water / Navien NR-240-A Combustion Analysis?
  • Post a Reply to this Thread
    Navien NR-240-A Combustion Analysis? (2 Posts)
  • SpeyFitter SpeyFitter @ 2:54 PM
    Contact this user
    Hey guys - I've sent Navien an email about this but I want to see if anyone in here knows as well. I've read through the instruction manual included with the unit and other then recommended gas pressure range, I can not find any combustion (analysis) specifications. Anyone know?  (I'm a Class 'A' Gas Fitter in BC Canada commissioning some of these at work - I WILL be putting an analyzer on it).
    Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
  • aasquared aasquared @ 6:45 PM
    Contact this user
    Analysis
    I am curious if you have ever found out about the combustion readings as I am about to check one out. I too am a A fitter living in BC.
