The Wall
Forum / THE MAIN WALL / Quietest Boiler ?
  • Post a Reply to this Thread
    Quietest Boiler ? (6 Posts)
  • Andy Andy @ 12:00 PM
    Contact this user
    Quietest Boiler ?
    Hi All,
    I recently lost my home to the fires here in Colo. My house had a four zone hotwater system that I loved and maintained. Since I will be rebuilding I would like your opinions on which of the current model boilers are the quietest. The boiler will be on the same level as my home theater system so I want to keep the noise level as low as possible.
    I wish there was a way to test drive boilers like cars :)
    Thanks
    Andy
  • Robert O'Brien Robert O'Brien @ 12:59 PM
    Contact this user
    Gas,oil?
    Any gas mod/con is almost silent. With oil,System 2000 is quietest chimney vented. Firebird is quietest direct vent
  • Zman Zman @ 2:38 PM
    Contact this user
    Boilers
    You should be giving mod/cons a serious look.
    Triangle Tube, Lochinvar, and Viessmann are excellent boiler and are well supported in CO. Triangle Tube has training facility in Denver with operating boilers. You may be able to see one run there. You could also have your contractor show you a previous installation.
    Carl
  • Dobber Dobber @ 9:51 AM
    Contact this user
    Quiet
    I did a home last year that has a vito 100 next to theater room.No sound problems.
    Good Luck
    If you don't have time to do it right, what makes you think you have time to do it over?
  • gennady gennady @ 10:04 AM
    Contact this user
    pump
    i think pump noise will be bigger issue than mod con boiler noise.
    Gennady Tsakh
    Absolute Mechanical Co. Inc.
    www.AbsoluteMechanicalCoInc.com
  • hot rod hot rod @ 10:38 AM
    Contact this user
    installation matters also
    Have the installer mount the piping and pumps on flexible attachments.
    They have special metal tracks to fasten sheetrock to eliminate noise transmission, consider that for the mechanical room wall.
    I installed Lochinvar Cadet in my home recently. It has a thick foam insulation jacket around it for heat loss and noise reduction. Most of the new ECM circs are super quiet.
    Have them install a top quality air separator to eliminate any noise from the hydronic piping.
